Possible to change z coordinate for solid top surface?
Hello, I have developed a bounding box from a slab which i have modeled in REVIT. What i ultimately would like to do, is extrude that bounding box up in the z direction. Is there a way to do this?
Do you intend to make the bounding box taller? I would try to recreate a new bounding box with the same Min point and a translated (up in the direction) Max point
Yes, ultimately I’d like to just extrude to be taller. I have been looking for a way to change the max points, but cannot find anything. Is there a way to transform the max point to be taller?
Then I confirm the suggestion of before. Just create a new bounding box with a translated Max point. Here is an example of the code (red the original bounding box, green the new) :
I have tried this method but it seems it only works when the slab shape is a rectangle or square. When you have angled sides or openings in the slab it seems like it won’t change (translate). The outline on bottom of image is the original slab location, which i then had to move to match the shared coordinates (upper gray hatch). I then used method you mentioned and have tried previously, yet the bounding box does not change.
is normal that the bounding box doesn’t change, you are creating a new one. From your screen, we cannot see the difference between the bounding box.
Anyhow, the shape of the floor doesn’t influence this function. (In my example the slab was a triangle)
I am just seeing that after inputting the information i needed to see if the bounding box contained. I guess i was assuming that the box would change visually. Thank you for the help!
