Are there any nodes which can tell you if a point’s x and y coordinates are shared by a surface?
I’m copying a surface spot elevation to a grid based on the surface’s max/min x and y coordinates, but I would like to remove the points that are not over the surface:
You could use Surface.ElevationByXY, which would give a null if a point is off the surface. Then you could use List.FilterByBoolMask or List.Clean from there.
Actually ended up using the IsNull node, and a bool filter. Worked like a charm. Thank you!
