Hi there,
I am implementing some Dynamo nodes to interact with SharePoint.
I am currently using the PnP Core library; the problem is that I have this error when I set the HostService.
If I set the HostService when Dynamo is loading, the Host is null.
This is how the host is implemented, nothing different from how the PnP documentation suggests.
It seems a dlls problem, which ends with these levels of incompatibility.
A version of 7 or higher is necessary for PnP to function properly. However, Revit only uses version 3.1
The problem was Microsoft.Extension.Host version 7 instead of version 2.2.0 due to the PnP.Core targetting standard using Microsoft.Extensions.Configuration.Binder 2.2.0.
Hi @patrick.ericson
I finished developing the first two nodes to download files and folders from SharePoint, working both for Revit and Civil.
The next step will be to bring a bit of these functionalities.
