Placing Spot Elevations at the underside of piping runs
Hi everyone,
I am trying to place spot elevations for piping.
I’ve got the script working but the final piece to the puzzle for me, is how to slide a point along a plane that is slanted?
I am trying to get the points illustrated by the red arrows. What I currently have is the point to the center of the pipe, not the underside.
I have translated that point downwards by the Radius of the pipe, effectively getting the underside value for flat pipes.
When it comes to slanted pipes, I cant seem to create a point that is at the bottom of the pipe run, relative to its direction. I am trying to create a plane that is perpendicular to the curve vector, which I can then use to create a point at the under side of the pipe.
How do I create a plane that is perpendicular to the pipe, which I can use to slide the point down?
Also, if I am over thinking this and there is a node out there that does this, please let me know :see_no_evil:
Any advice or direction would be highly appreciated.
Thanks!
Hi @Sigma here is an example for ducts, could probably work for pipes as well
Revit_bqr5fpSTFa
Hi @sovitek - Thanks for helping me out again.
I recreated your script but I just get a null as the output
It is a bit different compared to ducting, so I might have done something incorrect. I’m not sure if you can spot anything?
no should work the same way on pipes, , be sure you only crap the arch in the codeblock, you could just use a remove if not instead would be better, but it was just a fast example…try as here
spotelev.dyn (31.0 KB)
Thanks that works!
Would you be able to guide me to a method which can accept multiple pipes rather than a single item?
I’m not sure I know how to deal with the list management from the code block after “Element.Faces” node?
yeah :wink: list level and some lacing,try play around with it and if you go stuck, then just show us your graph and we can try help…
Great, thank you!
Here is my attempt, I think it is pretty close? I get 4 points at the end of it, but for some reason, only 3 tags get placed. I get a null for the other point and I’m not sure why this is?
I tried transposing the list.create node, which give me the missing value, but then excludes some of the other values…
not sure, i never do it that way i always just use a duct tag for that kind, think its better and more stable
