Placing Dimension Between Filtered element
The below snap is for reference, As i want to place DIMENSIONS in between filtered element but the output is showing a warning shows that the view template cannot be used to get bounding box. @Nick_Boyts @sovitek i think you guys can help on this please .
We can’t quite read your image as the node titles are all missing. This means you were zoomed out too far when you took the screenshot. Read through how to use Export as Image and try again. Be sure to include the full text (or a screenshot) of any warnings or errors you’re getting. Dimensioning typically requires references for the leaders and locations for the dimension lines. The node you’re using seems to have default values (for something) but you’re likely missing a lot of info for dimensioning 23 different elements. Try searching for similar topics and see if you can find any helpful suggestions.
yeah zoom in so we can see whats goin on as Nick say as well..and what kind of structural foundation are we talking here, wall foundation?. isolated ?? floor slab edges ??
arhh now i see you get points so that most be isolated…try dimension and get reference from family from genius loci
The Error Showing as its a structural plan view and its not a view how do i solve this
@sovitek @Nick_Boyts Attached Snap for your Reference and Kind information
Error isn’t due to the view, but due to having a point instead of a geometry reference (the second input). Look into the extended node help for possible hints on how to use the node that is throwing an error (right click the node and hit ‘help’).
