Hi all. Hopefulyl I can explain what I’m trying to do clearly. I have created a bunch of Spaces in my model, but they aren’t placed anywhere in the model. You can only see them in the schedule:
Using the code block below ‘Element.SetLocation’ I can adjust the location if I place the space, but with it unplaced I get an error.
So I thought I’d try and re-write the node to figure it out, because in theory you should be able to just re-write the Location of the selected elements. However my Python skills are pretty limited at the moment, so my question is: In the ‘for’ loop how do I make sure that 'Element.Location.SetValue() is pointing at the right element ID? I’ve been looking for an example bit of code but had no luck. I think I can figure out the rest, it’s just this bit where I’m stumped.
Any direction is much appreciated!
Thanks,
Liam
