i created a dynamo to distribute the families on the path (one segment) how can i edit this to work with multi lines ? i try change the select element to select elements but fail this case i need help
You could also try this …
After you select all the lines using Select Model Elements change the lacing on Curve.PointAtDistance to CrossProduct
Eng BEN OSBORNE you are Expert thanks so much
No. Experts are guys like Dimitar, Konrad, Vikram, Andreas. I’m just handy.
