HI
I’m trying to place some selected elements at same location in another view (sheet), and i don’t know how.
Please help.
HI
Please help.
You can use the node Viewport.Create from Rhythm.
I don’t know what kind of views you want to place but you can not place a floorplan on two different sheets.
HI
Thanks for reply, but I don’t want to place new Views. I want to copy some elements from one sheet to another. Those are sheet headers.
I got the elements and the Points of location in the first view. Now i want to insert them in another view at the same location.
Thank you. It works, but i have to set the instance parameter to specific values.
It inserts a new type, and the instance parameter are set to default.
I need to copy the elements with the correct instance parameter
think i understand…then you had to set your instance parameter again…could you share the dyn ?
