Is it possible to place a detail group on multiple sheets? I can get dynamo to find the detail group, but not sure which node i need to use to place it onto sheets
Are you sure you want them on sheets and not in a view?
Yes on sheets - we have a wall schedule/legend which is a detail group and i want it placed on all our plan sheets
Can’t say I’ve seen this done manually - do you have an example? Any reason you’re not using a Legend view instead?
This is my detail group. The “wall schedule” is reading from the model, while the “wall legend” is just text and lines. I have grouped the two together so you only need to select one item to copy and paste to new views.
