Place component by point and orientation
Hi all!
How to do for placing the generic models following the vectors?
I will not use the rotation box because it rotates the components every time that the process start.
Thank You!
One of the possible way is to use ā€œGraham Scanā€ method. https://en.wikipedia.org/wiki/Graham_scan
Thank you Kulkul,
can I use this method for my case?
I’ve a list of points and a list of vectors, I would use these things for placing the generic models.
Follow the scheme below:
The other option is use a 2 point adaptive family.
I have done this for a tunnel project where segmented rings were placed based on 2 coordinates. The start and finish coordinates were generated in Dynamo from a single list
In other words- you only need to feed in a set of coordinates- but they must be in the right sequence.
The vector/rotation is defined by start/finish points
You could combine the ā€˜Curve.PointsAtDistance’ method with this approach
Andrew
What are you trying to place?
Can you show full screenshot of your work so far?
Yes!
As soon as possible, I will upload my work.
Working, I have an other question. Once placed the families, how to do for ā€œbakeā€ these families?
Because if I change the code, the families follow the changes. How to disconnect the link between the families just created and dynamo code?
Thank You!
