Pipe.Midpoint node is not working
Can anyone advise what the issue is?
I get the same result, either if I select a pipe or if I get all pipes in dwg
Not sure how the nodes is created because I can’t find any properties for pipe midpoint in the Pipe Class and Pipe Properties
There is a node in Arkance package to get midpoint between point
IMPORTANT!!
Depending on what point you are interested in you will only get the Centerline of pipe using this node.
If you want invert you need to use the Pipe.StartInvert and Pipe EndInvert to get the correct elevation for Pipe Invert
Can you enlarge the picture to understand the node names?
GetPipeByName node into both the Pipe.StartPoint and PipeEndPoint nodes just like you had before followed by one of the following:
  • a Point.Average node from Clockwork
  • GetMidPointFromTwoPoints node from Arkance,
  • A Line.ByStartPointEndPoint followed by Curve.PointAtParameter which are both out of the box nodes.
Sorry, my bad. I have updated the screenshot and correct from @jacob.small it should be Arkance package, not Camber :slight_smile:
upgraded graph for the inlet instead of centerline.
@riyasrasheedbc
Did you get the result you wanted?
Of course yes. Thank you for your prompt response :grinning:
