Pie Chart to Drafting View
here is the full version with input colors (Dynamo Colors)
import sys
import System
from System.IO import StringReader, FileStream, FileMode, MemoryStream, File, Path
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
clr.AddReference("LiveChartsCore")
clr.AddReference("LiveChartsCore.SkiaSharpView")
clr.AddReference("LiveChartsCore.SkiaSharpView.WPF")
clr.AddReference('SkiaSharp')
import LiveChartsCore
from LiveChartsCore import *
from LiveChartsCore.SkiaSharpView import *
from LiveChartsCore.SkiaSharpView import PieSeries
from LiveChartsCore.SkiaSharpView.WPF import *
from SkiaSharp import SKColors, SKColor, SKColorF
from LiveChartsCore.SkiaSharpView.VisualElements import LabelVisual
from LiveChartsCore.SkiaSharpView.Painting import SolidColorPaint
clr.AddReference("System.Xml")
clr.AddReference("PresentationFramework")
clr.AddReference("PresentationCore")
clr.AddReference("System.Windows")
import System.Windows.Controls
from System.Windows.Controls import *
import System.Windows.Controls.Primitives
from System.Xml import XmlReader
from System.Windows import LogicalTreeHelper
from System.Windows.Markup import XamlReader, XamlWriter
from System.Windows import Window, Application
from System.Windows.Media.Imaging import RenderTargetBitmap, PngBitmapEncoder, BitmapFrame
import traceback
import time
# https://v0.lvcharts.com/App/examples/v1/Wpf/Pie%20or%20Doughnut
class MainWindow(Window):
    LAYOUT2 = '''
        <Window xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
         xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
         xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
         xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
         xmlns:lvc="clr-namespace:LiveChartsCore.SkiaSharpView.WPF;assembly=LiveChartsCore.SkiaSharpView.WPF"
            Title="LiveCharts"
            Width="404"
            Height="500">
            <Grid>
                <Grid.RowDefinitions>
                    <RowDefinition Height="*"/>
                    <RowDefinition Height="Auto"/>
                </Grid.RowDefinitions>
                <UserControl Grid.Row="0" mc:Ignorable="d" d:DesignHeight="300" d:DesignWidth="500">
                    <Grid>
                        <lvc:PieChart Name="Chart" LegendPosition="Bottom" />
                    </Grid>
                </UserControl>
                <!-- Add the Save Chart button at the bottom -->
                <Button Grid.Row="1" Name="SaveButton" Content="Push on a draft view" Height="30" Margin="10"/>
            </Grid>
        </Window>'''
    def __init__(self, title, keys, values, ds_colors):
        super().__init__()
        self.title = title
        self._keys = keys
        self._values = values
        self._ds_colors = ds_colors
        self.img_stream = None
        xr = XmlReader.Create(StringReader(MainWindow.LAYOUT2))
        self.winLoad = XamlReader.Load(xr)
        # initialize a SeriesCollection and bind it to the PieChart
        self.seriesCollection = List[ISeries]()
        # populate the PieChart with data
        for key, value, ds_color in zip(keys, values, ds_colors):
            pie_series = PieSeries[float]()
            pie_series.Values = [value]
            pie_series.Name = key
            # convert dynamo color to hex color
            hex_color = "#{:02X}{:02X}{:02X}".format(ds_color.Red, ds_color.Green, ds_color.Blue)
            sk_color = SKColor.Parse(hex_color)
            pie_series.Fill = SolidColorPaint(sk_color)
            self.seriesCollection.Add(pie_series)
        self.InitializeComponent()
    def InitializeComponent(self):
        try:
            self.SaveButton = LogicalTreeHelper.FindLogicalNode(self.winLoad, "SaveButton")
            self.SaveButton.Click += self.save_button_clicked
            self.Chart = LogicalTreeHelper.FindLogicalNode(self.winLoad, "Chart")
            self.Chart.Series = self.seriesCollection
            # set the title using LabelVisual
            lb_title = LabelVisual()
            lb_title.Text=self.title
            lb_title.TextSize=20
            lb_title.Paint=SolidColorPaint(SKColors.Black)
            self.Chart.Title = lb_title
        except Exception as ex:
            print(str(ex))
    def save_button_clicked(self, sender, args):
        """Event handler for the Save Chart button click"""
        try:
            self.save_chart_to_memory()
            self.winLoad.Close()
        except Exception as e:
            print(f"Error saving chart as image: {e}")
    def save_chart_to_memory(self):
        try:
            # use RenderTargetBitmap to capture the visual content of the chart
            dpi = 300
            size = self.Chart.RenderSize
            width = int(size.Width * dpi / 96)
            height = int(size.Height * dpi / 96)
            render_bitmap = RenderTargetBitmap(width, height, dpi, dpi, System.Windows.Media.PixelFormats.Pbgra32)
            # Render the chart's visual tree to the RenderTargetBitmap
            render_bitmap.Render(self.Chart)
            # Prepare to save the rendered bitmap to a file
            encoder = PngBitmapEncoder()
            frames = List[BitmapFrame](encoder.Frames)
            frames.Add(System.Windows.Media.Imaging.BitmapFrame.Create(render_bitmap))
            encoder.Frames = frames
            # save image to memoryStream
            self.img_stream = MemoryStream()
            encoder.Save(self.img_stream)
            # reset the memory stream position to the beginning
            self.img_stream.Seek(0, System.IO.SeekOrigin.Begin)
            print(f"Chart successfully saved to memomry")
def create_draft_view(view_name):
    filter_Name = System.Predicate[System.Object](lambda x : x.ViewFamily == ViewFamily.Drafting )
    view_family_type = List[Element](FilteredElementCollector(doc).OfClass(ViewFamilyType).ToElements()).Find(filter_Name)
    drafting_view = ViewDrafting.Create(doc, view_family_type.Id)
    try:
        drafting_view.Name = view_name
    except:
        drafting_view.Name = f"{view_name}_{int(time.time())}"
    return drafting_view
def create_image_on_draft_view(img_stream, view_name):
    dft_view = create_draft_view(view_name)
    temp_file_path = Path.GetTempFileName()
    temp_file_path_png = Path.ChangeExtension(temp_file_path, ".png")
    with File.OpenWrite(temp_file_path_png) as temp_file_stream:
        img_stream.CopyTo(temp_file_stream)
    image_options = ImageTypeOptions(temp_file_path_png, False, ImageTypeSource.Import)
    placement_options = ImagePlacementOptions()
    placement_options.PlacementPoint = BoxPlacement.Center
    placement_options.Location = XYZ.Zero
    image_type = ImageType.Create(doc, image_options)
    image_instance = ImageInstance.Create(doc, dft_view, image_type.Id, placement_options)
    TransactionManager.Instance.ForceCloseTransaction()
    uidoc.RequestViewChange(dft_view)
    return image_instance
my_window = MainWindow(IN[0], IN[1], IN[2], IN[3])
my_window.winLoad.ShowDialog()
if my_window.img_stream is not None:
    OUT = create_image_on_draft_view(my_window.img_stream, my_window.title)
Thank you for that c.poupin. Now to compare and see what I was doing wrong. :slight_smile:
