Hi
Just wondering if there is a way to extract drawings from pdf files to detail lines?
In CAD, we just open it with illustrator and then export it as .dwg file.
Maybe some pack or python node could resolve this?
Thank you
Hi
Thank you
If you can find a way to read a PDF directly, this may be possible. Iād guess a 0-touch node would be the key.
Meanwhile, AutoCAD 2017 has a great PDF converter. Use the DWG however it helps you.
