Hi All,
I have created a python script for duct support. But the problem is that if I change the family path location and after that run the script that time one error massage is coming regarding the family location. I am not understand why script is not taking the family from the changes location. I have attached error massage snap as well as whole script. Please help me.
# import libraries
import sys
import math
import System
clr.AddReference('RevitAPI')
from RevitServices import *
from Autodesk.Revit.DB.Mechanical import *
from Autodesk.Revit.DB.Plumbing import *
from Autodesk.Revit.UI.Selection import *
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
family_path = 'G:\dynamo practice\hanger'
clr.AddReference("System.Windows.Forms")
clr.AddReference("System.Drawing")
clr.AddReference('System.Windows.Forms.DataVisualization')
from System.Windows import Forms
from System.Windows.Forms import Application, Form, Button, Panel, Label, ComboBox, DialogResult, ListBox, TextBox,OpenFileDialog
from System.Windows.Forms import Button, AnchorStyles, StatusBar, ListView, View, ColumnHeader, ListViewItem, SortOrder, FormBorderStyle,FolderBrowserDialog, DialogResult
from System.Drawing import Size, Point, Font, Color
import os
from System.IO import Directory, Path, SearchOption
#dist = IN[1]
#od = dist
distfromEdge = IN[2]
def itof(inc):
ft = (inc / 12.00)
return ft
def findPath ():
dialog = FolderBrowserDialog()
s = dialog.ShowDialog()
if s == DialogResult.OK:
path = dialog.SelectedPath
return path
#========================================Element angle property =======================================================
def angle(pt1, pt2):
x1 = pt1.X
x2 = pt2.X
y1 = pt1.Y
y2 = pt2.Y
if round(x1, 2) == round(x2, 2):
ang = math.radians(90)
elif round(y1, 2) == round(y2, 2):
ang = math.radians(0)
a = pt1.DistanceTo(pt2)
o = y2 - y1
sinT = o / a
ang = math.asin(sinT)
return ang
#========================================End Element angle property =====================================================
#================================== Retreiving Duct shapes ======================================
def shape(el):
cm = el.ConnectorManager.Connectors
for i in cm:
sh = i.Shape.ToString()
return sh
#============================= End Retreiving Duct shapes ======================================
#======================================== Z axis =======================================================================
def zaxis(obj):
i_point = obj.Location.Point
s_point = XYZ(i_point.X,i_point.Y,i_point.Z+1)
za = Line.CreateBound(i_point,s_point)
return za
#====================================== Collect hanger family =================================================
def findFname (duct):
cr1 = FilteredElementCollector(doc).OfClass(FamilySymbol).ToElements()
if shape(duct) == "Rectangular":
for i in cr1:
if i.FamilyName.ToString() == "sh_rec_hanger_type-1":
familyName = i
elif shape(duct) == "Round":
for i in cr1:
if i.FamilyName.ToString() == "sh_rnd_hanger_type-1":
familyName = i
pass
return familyName
#====================================== End Collect hanger family =================================================
#======================================== SELECT DUCT ===================================================================
selIds = uidoc.Selection.GetElementIds()
ducts = []
dName = []
if selIds:
idList = []
for id in selIds:
dt = doc.GetElement(id)
if dt.Category.Name.ToString() == "Ducts" :
ducts.append(dt)
pass
ducts = []
rectangleDuctList = []
roundDuctList = []
#if len(ducts) != 0:
hangerList = ["sh_rec_hanger_type-1","sh_rnd_hanger_type-1"]
familyFilterName = []
lenhangerList = len(hangerList)
familyFilter = FilteredElementCollector(doc).OfClass(FamilySymbol).ToElements()
for fn in familyFilter:
familyFilterName.append(fn.FamilyName)
for hangerName in hangerList:
if hangerName not in familyFilterName:
family_path = findPath()
break
if family_path:
for ha in hangerList:
fname = family_path + "\\" + ha + ".rfa"
t = Transaction(doc, "place hanger")
t.Start()
doc.LoadFamily(fname)
doc.Regenerate()
t.Commit()
pass
familyCollector = FilteredElementCollector(doc).OfClass(FamilySymbol).ToElements()
for j in familyCollector:
if j.FamilyName in hangerList:
t = Transaction(doc, "make active")
t.Start()
if j.IsActive == False:
j.Activate()
doc.Regenerate()
pass
t.Commit()
pass
dcidList = []
if len(ducts) != 0:
ductLengthList = []
raList = []
countList = []
evaluatedPointList = []
for du in ducts:
ductLength = du.GetParameters("Length")[0].AsDouble()
#dist = IN[1]
od = IN[1]
if ductLength <= IN[2] * 2 :
dist = ductLength / 2
ra = 1
dist = IN[2]
realductLength = ductLength - (IN[2] * 2)
ra = int((realductLength / IN[1]) +2)
#ra = int((ductLength / IN[1]) +1)
count = 0
while count < ra:
if count == 1:
dist = ductLength - IN[2]
elif count == 2:
dist = IN[2] + od
else :
dist = dist
line1 = du.Location.Curve
st_pt1 = line1.GetEndPoint(0)
end_pt1 = line1.GetEndPoint(1)
level = du.ReferenceLevel
ang = angle(st_pt1, end_pt1)
ductAngle = ang + math.radians(90)
st_ppt1 = line1.GetEndParameter(0)
end_ppt1 = line1.GetEndParameter(1)
paramCalc = st_ppt1 + dist
tof = line1.IsInside(paramCalc)
normParam =line1.ComputeNormalizedParameter(paramCalc)
evaluatedPoint = line1.Evaluate(normParam,tof)
s_point = XYZ(evaluatedPoint.X,evaluatedPoint.Y,evaluatedPoint.Z+2)
axis = Line.CreateBound(evaluatedPoint,s_point)
o = du.GetParameters("Bottom Elevation")[0].AsDouble()
if shape(du) == "Rectangular":
w = du.GetParameters("Width")[0].AsDouble()
fname = findFname(du)
#familyName = "sh_rec_hanger_type-1"
ductShape = "duct width"
elif shape(du) == "Round":
w = du.GetParameters("Diameter")[0].AsDouble()
#familyName = "sh_rnd_hanger_type-1"
ductShape = "Diameter"
pass
t.Start()
dc = doc.Create.NewFamilyInstance(evaluatedPoint,fname,level,StructuralType.NonStructural)
dcid = dc.Id
ElementTransformUtils.RotateElement(doc,dcid,axis,ductAngle)
#dc.LookupParameter("duct width").Set(w)
dc.LookupParameter("Offset").Set(o)
dc.LookupParameter(ductShape).Set(w)
t.Commit()
count +=1
dist += od
ducts = "Nothing selected"
#=================================== Retreiving linked models ===========================================================
OUT = ducts
sh_rec_hanger_type-1.rfa (340 KB) sh_rnd_hanger_type-1.rfa (364 KB)
