I have created curves in dynamo, in family creator, and I have a problem with exporting them to project. How it can be done? Or is there a way to link two dynamo scripts which work and different documents?
Yes, because I need to use nested families instancies paramaters and its points. Btw I figure out that I can pass it using static property in ZeroTouch, but I’m still curious how it could be done without C#.
You can serialize your data to a JSON file in one script and read data in the other.
I have once made a geometry generator in stand-alone python that was exchanging data with Dynamo via json file in almost real-time. Dynamo has been set to automatic mode and was re-reading the file whenever modified.
