Hi there,
I’m trying to make a script in order to place parking spots between columns and I think I’m very close, but somehow I can’t get past this error:
The thing is geometry.translate’s geometry and direction are correct. In order to get the distance, I used a Sequence, and as far as I’m concerned both inputs ‘amount’ and ‘step’ are correct. However I don’t really know what to make as an input for ‘start’. What I need is the start to be the point where the other face of the column starts. I made a script to get that coordinate for each column, but I don’t really know how to connect it, since the ‘start’ input requires a number.
That was a great idea. However, I tried to do it and still no result… the Sequence is somehow correct, but not the geometry.translate , as Xs are displaced the first number (-12.769…). I also tried geometry.translate ing the geometry that distance (+12.769…) but it doesn’t work either…
