Does anyone know how to deal with elements that have the same parameter name? For example, curtain wall has a “Number” parameter, one relating to vertical grid and the other to horizontal. How do you deal with this? Running in Dynamo will give mixed results: sometimes it will pull the vertical one, other times the horizontal one.
Related topics
| How to set a parameter value if there a 2 with the same name? | 4 | 165 | September 13, 2023 | |
| How to Element.SetParameterByName if there are two identical name of parameters? | 7 | 1278 | June 5, 2025 | |
| Setting Parameters by ID | 1 | 498 | August 14, 2021 | |
| Set parameter with the same name to different value | 8 | 212 | October 5, 2023 | |
| Due to same name of parameter dynamo found confution | 2 | 375 | June 26, 2019 |
