I'm trying to import two sets of lines, one in plan and one in section. These lines are already drawn in 2D. I'll use these lines as the framework for creating a sweeping or rail surface.
I'm getting frustrated because I can't seem to find a way to import the section lines and have them orient to a vertical reference plane. When I import the CAD file the vertical reference planes I have set up do not appear in the "Place At" pulldown.
Phil, After importing the CAD file, you will have to select it and explode it. The, select individual (or groups of) lines and you will see a "Pick New" icon in the ribbon. This will let you pick a new reference plane to place the lines on.
