Hi everyone,
I’m trying to make a 1 sheeted hyperboloid with rotation in the upper curve and cross wires. Everything is fine but when I want to create some quad points for aplying an adaptive family quad panel it’s not working. I’m trying to use List.Subslists node but I don’t get it completely.
Any ideas? Thanks
Hiperboloide 1 sheet.dyn (145.5 KB)
If you could create more intersections and clean up your graph, you could create a NurbsSurface from it.
Don’t know if it helps, but working with the surface gives you new options to divide it.
Below are points that form a surface. The same can be used to place adaptive components
Hiperboloide-Paneling.dyn (66.4 KB)
I didn’t see your replay in time so I did it by myself.
It is working perfectly but your script is much cleaner, better and faster.
Thanks for your help and knowledge
Thanks Marcel but I don’t have the control I need on the wires with a nurbs surface.
