I am importing sketchup models… but the render material is gray, the shading is fine…
So i am making a script, create a new appearance asset and i want to give it the graphic shading color…
It works for some…but i also get an error on some colors…why it is a normal color
the warning is:
Warning: Graphics.GetShadingColor operation failed.
The color represents an invalid or uninitialized color.
in this thread, i read that it might has to do something with imported materials… i am using an imported sketchup model.
What would be strange because i see a color RGB 255 84 84 so why can’t it get that data…
Hi Arno,
I can’t help you with the Orchid node, but did you try with the OOTB node and the Genius Loci node ?
yes did try … it is a problem with imported materials
You can drop a sample Revit file with your imported materials if you need some assistance.
boat.rfa (1.5 MB)
This is a file with an imported sketchup model… the material nodes won’t work on it, who has a solution… because it is strange that shaded does have a color
It seems there is no solution.
It is written in the API : “Colors obtained from some API methods may represent an uninitialized/invalid color.”
