I’m working on creating an attractor system that is based on a point that is generated from an evaluated UV surface. I created an integer slider to select a specific point from the list of xyz’s of the surface, but now I need to omit that point from the original list in order to generate the distance relationships. Otherwise I’m getting an error when I try to generate a line to visulize the distances similar to the tutorial file. I’m not seeing a list node that does this and I’m wondering what operation I need to do in order simply subtract this point from the original list. I’m working in build Build 0.6.3.7993. Thanks.
How about Remove From List?
ah ha! Thank goodness. That node doesn’t display in the search for list! Thanks Andreas!
