# Offset Alignment start and End station
**URL:** <https://forum.dynamobim.com/t/offset-alignment-start-and-end-station/76077>\
**Category:** Civil 3D\
**Created:** [May 2, 2022, 10:53am UTC](https://forum.dynamobim.com/t/offset-alignment-start-and-end-station/76077 "2022-05-02T10:53:28Z")\
**Showing post:** 2
**Author:** ![Assem.Daaboul](https://sea2.discourse-cdn.com/flex022/user_avatar/forum.dynamobim.com/assem.daaboul/32/116900_2.png) [@Assem.Daaboul](https://forum.dynamobim.com/u/Assem.Daaboul)\
**Post date:** [May 4, 2022, 8:26am UTC](https://forum.dynamobim.com/t/offset-alignment-start-and-end-station/76077/2 "2022-05-04T08:26:46Z")
> [@CreateOffsetAlignment Python script Fatal Error](https://forum.dynamobim.com/t/createoffsetalignment-python-script-fatal-error/65426/10):
> Hi, Below is a quick (probably requires a lot of cleaning) solution to use the start and the end station while creating offset alignment. I’ve used the [Alignment.CreateOffsetAlignment Method (database, offset alignment name, parent alignment name, offset, style, start station, end station)](http://docs.autodesk.com/CIV3D/2019/ENU/API_Reference_Guide/html/c8e55380-864b-430b-b863-d5aa410df19d.htm) to create the offset alignments. Note the additional import [from Autodesk.Civil import \*] # Load the Python Standard and DesignScript Libraries import sys import clr # Add Assemblies for AutoCAD and Civil3…
_[View the full topic](https://forum.dynamobim.com/t/offset-alignment-start-and-end-station/76077)._
