# Node to stop / quit running dynamo graph
**URL:** <https://forum.dynamobim.com/t/node-to-stop-quit-running-dynamo-graph/25892>\
**Category:** Developers\
**Tags:** dynamo\
**Created:** [September 14, 2018, 7:46am UTC](https://forum.dynamobim.com/t/node-to-stop-quit-running-dynamo-graph/25892 "2018-09-14T07:46:43Z")\
**Showing post:** 2
**Author:** ![Jonathan.Olesen](https://sea2.discourse-cdn.com/flex022/user_avatar/forum.dynamobim.com/jonathan.olesen/32/44242_2.png) [@Jonathan.Olesen](https://forum.dynamobim.com/u/Jonathan.Olesen)\
**Post date:** [September 14, 2018, 8:07am UTC](https://forum.dynamobim.com/t/node-to-stop-quit-running-dynamo-graph/25892/2 "2018-09-14T08:07:56Z")
Have a look at using the OOTB “ScopeIf” node 🙂
You could be inspired by this post if you’d like:
> [@Using ScopeIf to reduce calculation time by pulling results from previous runs (if already calculated)](https://forum.dynamobim.com/t/using-scopeif-to-reduce-calculation-time-by-pulling-results-from-previous-runs-if-already-calculated/21467):
> Hi all Sparked by @Michael_Kirschner2 comment on this issue: I have a workflow that calculated the weight of a structure using Robot, this happens inside a custom node powered by a randomly created number of parameters. As I’m using a genetic algorithm I’m bound to end up having calculation that are dublicates of already completed calculation. But as Michael mentions then “ScopeIf” could mean that I can pull the information from a .csv file and not execute that calculation. (A calculation ta…
_[View the full topic](https://forum.dynamobim.com/t/node-to-stop-quit-running-dynamo-graph/25892)._
