Hello all,
I am trying to sweep a circle along a curve but the run never ends (let it run for 4 hours while I was busy with other things). The Curve has a flat spot near the middle and I think that is whats casing the problem. I have attached the rvt and dyn files. I can get the sweep to work on a similar curve without the flat spot. Do any of you have a suggestion?
test_2.dyn (31.5 KB)
spiral.rvt (1.0 MB)
