Similar to this post, though this does not fully answer the problem: How to use two working ranges at the same time
I have a problem with a script in which I need to use Large working range in order to include all elements collected in the Revit model (Coordinates are above the 10,000 units limit), however doing so causes the capture of geometry to fail (requires the medium working range). Does anyone know a work around?
Changing units from mm to cm works but makes the preview very clunky and difficult to use.
