Good afternoon!
Need help with the DoesIntersect node. For some reason it gives true even when the geometry does not intersect.
Essence: copy existing trays horizontally up, vertical left or right, and connect parts either to the left or to the right. After copying, I reduce their width and radius (according to the formula, according to the curve, outward or inward). After I try to check whether the item has been copied to the right side (by default, they are copied first to the left). I check by a method I take a geometry of an element and I submit on comparison in a node DoesIntersect. And on zadumke-if there is an intersection, it must be transferred in the opposite direction, but for some reason it gives out that it always intersects and, accordingly, transfers everything. It is clearly seen in the test file that the new connection details were transferred in the wrong direction. Does this node check for the boxing boxes or something else? Can eat any other way to learn, in what side to copy an element?
I would be very grateful for the help!
Test rvt and dyn, you can open and just run, the script will work and you will see what is wrong.
