Hi there,
I have two requests for the functionality of the 3D-background preview.
Could it be possible that ‘zoom to fit’ would actually zoom to just the generated objects in Dynamo, not including the origin?
Could it be possible for orbiting in the 3D-background, to change the orbiting center to the center of the generated objects, instead of the origin?
The main reason I ask this is because I’m using Dynamo in a project environment most of the time. My Revit units are millimeters, and since Dynamo uses these same units since 0.8 (which in itself is great BTW), the numbers get quite big very quickly.
If I have small objects at ca. 500 meters from the Revit Origin, it’s coordinates in Dynamo are 500000 mm away from the origin, which makes it almost impossible to see in the 3D- background, let alone zooming and orbiting.
Thanks in advance
