Multi category tags, Category by name error
Hello all, i have a weird problem…
I have found half of my solution allready which is in this post:
To be able to get the elements of multi category tags Category, i used the python script as instructed in that post.
However…
I dont want to use dropdown menu nodes for obvious reasons, so i am trying to use the Category by name node, which gives me the same problem.
I cant give the python script the category name as input because it gives an error message…
Can anyone tell me how to resolve this?
I want to enter the category by string into the python script, so the drop down menu doesnt shift when i open the script in another project…
Below the python script:
clr.AddReference(“RevitAPI”)
from Autodesk.Revit.DB import FilteredElementCollector
def tolist(obj1):
if hasattr(obj1,“iter”): return obj1
else: return [obj1]
cat = UnwrapElement(IN[0])
OUT =
ueWrapper = None
wrappers = clr.GetClrType(Revit.Elements.ElementWrapper).GetMethods()
for w in wrappers:
if w.ToString().startswith(“Revit.Elements.UnknownElement”):
ueWrapper = w
break
if ueWrapper is not None:
fec = FilteredElementCollector(doc).WhereElementIsNotElementType()
if cat is not None:
fec = fec.OfCategoryId(cat.Id)
view_el =
for e in fec:
view_el.append(ueWrapper.Invoke(None, (e, True) ) )
OUT.append(view_el)
turn into checkboxes without a space for some reason…
Thanks! That worked :slight_smile:
Could you explain why “Multi-Category Tags” doesnt work?
Even when i get the category name with the "Category name"node it gives me “Multi-Category Tags” as the proper name.
I’m not 100% sure about it.
But this has been discussed over the forum quite a few times in the past.
Search for it and you will find the answer!
You can start here:
And if you have trouble locating the OST name for a category (like you had with Multi-Category Tags), this script would be your go-to tool:
