Move point coordinates down to the lowest plane of the floor or beam
I have the points represented by the sphere. i want to move the coordinates down to the lowest plane of the beam or foundation. How to choose the lowest plane?
p1.rvt (7.5 MB)
Move the location points a long way down (under the beams), then use a raytrace node (data shapes has one) to find the first point above it using rays pointing in the Z direction (up). You can check the Z difference to that point versus current to move it downward or use element.setlocation it its a point based family.
What about the Project Point node in the Z-direction?
I think it depends how variable your structure is, if there is a risk that people are doing lots of manipulation to the instance, Gavin’s solution is the most robust, however it might not be the fastest…
If the beam / foundation is not being edited, you could just grab their type Height / Thickness and move the point -Z?
You can grab the beam / foundation geometry and intersect the point -Z, as Daan said, but you might find some geometry not being extracted correctly and I’m not sure if it’s faster than Gavin’s method.
Hope that helps,
Mark
If the bottom is always a horizontal plane, you could just make a list of all the geometric surfaces and simply pull the smallest Z-value from all the origins and update your point using that value. That should be pretty quick.
A sloping beam would be more difficult.
