Hi. When I draw walls off a DWG sometimes you get walls not at a rounded parallel spacing. So I’m hoping to select a grid. Find all walls parallel to it then round the location of it to the nearest 10. This has become a nightmare Walls that are already rounded 5 I left not to be moved because there probably already sorted like perimeter walls. Any wall not I want to move to rounded 10. However If a walls 90 thick and your using the center location line. Youll move to a rounded 5 number not 10. Using the walls outer core location to calculate the distance you want to move so its rounded 10 becomes super confusing. Because you have to relate the wall thickness back to the center line of the original wall location.
this works for rounded 5
