Modified Type Parameters
Hi !
I’m new dynamo user and i easily succes to do something i didn’t arrive with vb net API. I would like to do this actions :
I get a specific type by selection and then automatically asign the value 66 to the shared type parameter “SD1”. I would like to do it with vb net /c # but i failed at the first step : get the type by visual selection.
Can you help me ?
I just arrived to change instance parameter value with that :
’ Select some elements in Revit before invoking this command
’ Get the handle of current document.
Dim uidoc AsUIDocument = commandData.Application.ActiveUIDocument
Dim doc AsDocument = uidoc.Document
’ Get the element selection of current document.
Dim selection AsSelection = uidoc.Selection
Dim selectedIds AsICollection(OfElementId) = uidoc.Selection.GetElementIds()
If 0 = selectedIds.Count Then
’ If no elements selected.
TaskDialog.Show(“Revit”, “You haven’t selected any elements.”)
Else
Dim info As[String] = "Ids of selected elements in the document are: "
Dim vbLf AsDouble
Dim vbTab AsDouble
ForEach id AsElementIdIn selectedIds
Dim e AsElement = uidoc.Document.GetElement(id)
Using y AsNewTransaction(doc, “Rens SD”)
If y.Start = TransactionStatus.Started Then
Dim RYparam AsString = “SD1”
Dim RYidparam AsIList(OfParameter) = e.GetParameters(RYparam)
Dim RYparamvalue AsParameter = RYidparam.First
RYparamvalue.Set(“66”)
EndIf
y.Commit()
EndUsing
'info += vbLf & vbTab + id.IntegerValue
Next
Thanks Sylvain
