Why do I only get one Height? I would expect there to be 171, the result is the same if I cycle the list.
You’re parameterName is in Level.
That is because you receive one value.
Remove the brackets from the “Height” or change lacing to longest.
Removed the brackets around “Height” solved it, had been trying with [“Height”,“Width”] first, but that did not work so I thourght Id give it a try with just Height, but didnt remove the brackets.
