Ok, it worked! That’s what I get for trying to install at 1am.
Dynamo has been so much fun to use and experiment with. Looking forward to whatever new features you guys come up with.
Thanks a bunch, Michael!
Update from my side:
as for now with DynamoCoreRuntime_2.13.0.2363_20210825T0513.zip it worked without error. I’m not sure if it is because of the latest Dailybuild or my system… But with the above version it is working just fine…
Greetings from Dynamo team, so if I understand it correctly. With the same setup of computer but different version of Dynamo 2.13, you see two different type of behavior of library view on the left of Dynamo window?
This may have been fixed for users with UK language setup, our team tested on one other language with a unlocalized build but still see same problem. We need your help on validating this issue with latest daily again, could anyone help?
