David2
#1
I will keep it short:
I am trying to run a circle node and it gives me the following error message:
“Methode nicht gefunden: “Autodesk.Revit.DB.Arc Autodesk.Revit.Creation.Application.NewArc(Autodesk.Revit.DB.XYZ, Double, Double, Double, Autodesk.Revit.DB.XYZ, Autodesk.Revit.DB.XYZ)”.”
All the mentioned methods are missing.
I am using Revit 2015. Students Version.
Would appreciate any help!
Thanks,
David
Hello David,
Can you please post a picture with the error which you are getting on Nodes?
Are you on German Locale? Can you try with English locale?
Thanks,
Ritesh
David2
#3
Hello Ritesh,
Thanks for your reply!
I am using an englisch version of Revit as well as Dynamo, but I am on a German computer.
Please see attached a screenshot of the error. I believe a folder of some components are missing…
Best,
David
seems you are using dynamo 6.3
in 7.xx its working fine:
David2
#5
Indeed, it is working fine with the update now.
Thanks!
