Hi All,
I am trying to include MEP system condition inside my script. Basically what I want to do is to specify airflow for all air terminals only inside supply air system. So far I have been able to achieve correct script only for all terminals (without any systems condition). Please see below where I want to add MEP system condition.
Best regards, Branimir.
I believe there are quite a few examples of this already on the forums (some for piping systems, but it’s the same thing). System Type and System Classification are parameters just like anything else. You need to get the parameter values for your elements then filter out the elements with the specific value you want, in this case Supply Air.
Try taking a look at this post and see if that gets you started.
