I was creating to split the duct where there is clash. Its almost working perfectly but some time its throwing memory error as shown below. please help me to identify the issue.
code is below:
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
import math
clr.AddReference("RevitAPI")
from System.Collections.Generic import Dictionary
app = uiapp.Application
Felem = UnwrapElement(IN[0])
Selem = UnwrapElement(IN[1])
from Autodesk.Revit.UI.Selection import *
#element angle property
def angle(pt1, pt2):
y1 = pt1.Y
y2 = pt2.Y
a = pt1.DistanceTo(pt2)
o = y2 - y1
sinT = o / a
ang = math.asin(sinT)
return ang
#end element angle property
#selecting first element and retreiving values
ref1 = uidoc.Selection.PickObject(ObjectType.Element)
eid = ref1.ElementId
elem1 = doc.GetElement(eid)
elem1curve= elem1.Location.Curve
elem1sp1 = elem1curve.GetEndPoint(0)
elem1sp2 = elem1curve.GetEndPoint(1)
# End selecting first element and retreiving values
# Selecting second element and retreiving values
ref2 = uidoc.Selection.PickObject(ObjectType.Element)
eid2 = ref2.ElementId
elem2 = doc.GetElement(eid2)
elem2curve= elem2.Location.Curve
elem2sp1 = elem2curve.GetEndPoint(0)
elem2sp2 = elem2curve.GetEndPoint(1)
elem2Width = elem2.GetParameters("Main Primary Width")[0].AsDouble()
elem2Depth = elem2.GetParameters("Main Primary Depth")[0].AsDouble()
elem2bottom = elem2.GetParameters("Bottom")[0].AsDouble()
elem2top = elem2.GetParameters("Top")[0].AsDouble()
# Find intersection and split point
elem1bb = elem1.BoundingBox[doc.ActiveView]
elem1outline = Outline(elem1bb.Min, elem1bb.Max)
elem2bb = elem2.BoundingBox[doc.ActiveView]
elem2outline = Outline(elem2bb.Min, elem2bb.Max)
outlineintersect = elem1outline.Intersects(elem2outline, 0).ToString()
if outlineintersect == "True" :
temppt1 = XYZ(elem2sp1.X , elem2sp1.Y , elem1sp1.Z)
temppt2 = XYZ(elem2sp2.X , elem2sp2.Y , elem1sp2.Z)
templine = Line.CreateBound(temppt1 , temppt2)
results = clr.Reference[IntersectionResultArray]()
result = elem1curve.Intersect(templine,results)
iResult = IntersectionResult()
intersectionpoint = results.get_Item(0).XYZPoint
newcurve1 = Line.CreateBound(intersectionpoint, elem1sp2)
newpoint1 = newcurve1.GetEndParameter(0) + elem2Width
tof = newcurve1.IsInside(newpoint1)
normParam1 = newcurve1.ComputeNormalizedParameter(newpoint1)
evaluatedPoint1 = newcurve1.Evaluate(normParam1,tof)
newductid1 = elem1.SplitStraight(evaluatedPoint1)
elem1a = doc.GetElement(newductid1)
elem1List = [elem1 , elem1a]
if len (elem1List) > 1:
for elem in elem1List:
elem1curve= elem.Location.Curve
elem1bb = elem.BoundingBox[doc.ActiveView]
result1 = elem1curve.Intersect(templine,results)
iResult1 = IntersectionResult()
newcurve1 = Line.CreateBound(intersectionpoint, elem1sp1)
newpoint = newcurve1.GetEndParameter(0) + elem2Width
tof = newcurve1.IsInside(newpoint)
normParam = newcurve1.ComputeNormalizedParameter(newpoint1)
evaluatedPoint = newcurve1.Evaluate(normParam , tof)
elem.SplitStraight(evaluatedPoint)
newduct = elem
comment = "Found list"
newduct = "No clash - Duct not splitted"
#End Find intersection and split point
newElevation = float(elem2top) + 0.083
newduct.LookupParameter("Bottom").Set(newElevation)
OUT = newduct,float(newElevation),elem2top
@SHIBUJOSE ,
just for better reading
import sys
sys.path.append(‘C:\Program Files (x86)\IronPython 2.7\Lib’)
import System
import math
clr.AddReference(“RevitAPI”)
clr.AddReference(“RevitAPIUI”)
y1 = pt1.Y
y2 = pt2.Y
o = y2 - y1
sinT = o / a
return ang
#End selecting first element and retreiving values
#Selecting second element and retreiving values
elem2Width = elem2.GetParameters(“Main Primary Width”)[0].AsDouble()
elem2Depth = elem2.GetParameters(“Main Primary Depth”)[0].AsDouble()
elem2bottom = elem2.GetParameters(“Bottom”)[0].AsDouble()
elem2top = elem2.GetParameters(“Top”)[0].AsDouble()
#Find intersection and split point
if outlineintersect == “True” :
results = clr.ReferenceIntersectionResultArray
newduct = elem
comment = “Found list”
newduct = “No clash - Duct not splitted”
newduct.LookupParameter(“Bottom”).Set(newElevation)
double else: does not work!
i would recomment post your code again </> #use this!
If statement should be inside the for loop (if outlineintersect == “True” : ). You have put it outside the for loop. that is why you seeing two else.
try to release objects
# previous code
newduct = elem
# Release Objects
templine.Dispose()
newcurve1.Dispose()
evaluatedPoint.Dispose()
results.Dispose()
# rest of code
unfortunately issue not resolved
A little code review
I could not test without a rvt file, so it’s possible there are some errors
import sys
import System
import math
y1 = pt1.Y
y2 = pt2.Y
o = y2 - y1
sinT = o / a
return ang
#if outlineintersect == "True" :
if outlineintersect:
resultsA = clr.Reference[IntersectionResultArray]()
result = elem1curve.Intersect(templine,resultsA)
if result1 == SetComparisonResult.Overlap:
#iResult = IntersectionResult()
#intersectionpoint = resultsA.get_Item(0).XYZPoint
intersectionpoint = resultsA.Value[0].XYZPoint
#TransactionManager.Instance.EnsureInTransaction(doc)
#TransactionManager.Instance.TransactionTaskDone()
# Regenerate doc
doc.Regenerate()
resultsB = clr.Reference[IntersectionResultArray]()
result1 = elem1curve.Intersect(templine,resultsB)
# iResult1 = IntersectionResult()
#intersectionpoint = resultsB.get_Item(0).XYZPoint
intersectionpoint = resultsB.Value[0].XYZPoint
doc.Regenerate()
newduct = elem
