Does anyone have an idea for getting material properties and assets like physical and thermal data?
Currently do I need density (physical, mechanical) from materials used in a project for LCA.
Hi Eric,
Here’s a hint:
This was exactly what was needed, thanks a lot Pawel, and a thanks also goes to Dimitar Venkov for the answer in the suggested thread.
If others want an easy copy paste, the code is below here: (in a loop)
t1.append(doc.GetElement(i.StructuralAssetId).GetStructuralAsset().Density)
t2.append(doc.GetElement(i.ThermalAssetId).GetThermalAsset().Density)
BUT be careful!!!
Revit has this odd kind of internal units, which is totally ridiculous, but nevertheless.
units need to be converted: result*35.31466680911273 = SI unit (kg/m3)
I figured at last, that Revit has its own unit World :-S
The below is how to fix odd revit to SI units
unit = DisplayUnitType.DUT_KILOGRAMS_PER_CUBIC_METER
t1 = doc.GetElement(i.StructuralAssetId).GetStructuralAsset().Density
s1.append(UnitUtils.ConvertFromInternalUnits(t1,unit))
check DanEDU Dynamo package MaterialDensity for full code.
