Material Hatch Patterns Appearing Grey Depending on Scale in Revit
I am experiencing an issue in Revit where the material hatch patterns start to appear greyed out depending on the view scale. When I zoom out or change the scale, the hatch is no longer clearly visible, even though the material and pattern settings remain unchanged.
Could you please let me know what might be causing this behavior and if there is a way to prevent the hatch patterns from greying out based on scale?
Is there a recommended setting or workaround to ensure consistent visibility of material hatching at different scales?
Thank you in advance for your help.
Best regards,
This is more a Revit related question
and not a Dynamo one i feel.
That being said i am think
Model vs Drafting pattern.
