Lunchbox 2017.2.12 and DS 1.3.0
Hi I’m using DS 1.3.0, with a few packages installed i have uninstalled and then reinstalled them to determine if any of them are contributing to my issue.
  • When I use lunchbox i find that my background 3d preview is split vertically with soem of the geometry disappearing behind white space… think the problem is with lunchbox
  • three images attached: first is the full image panned to the left and the second is the preview rotated around its Z axis centre of the 3 d background preview, third is rotated slightly further until the geometry vanishes
Its quite odd I had this problem previously before in DS however it is not a problem when running Revit 2017 and Dynamo 1.3.0 on my office laptop.
Can anyone shed some light on this, its quite odd.
U_Frames_NR_Rev_A.dyn (42.6 KB)
Update it may not be Lunchbox at all, it may be the Surface.byPatch node…which I am using with rectangle.bywidthlength. Apologies Lunchbox!
