call me crazy…if statement doesn’t do what it needs to do…
Lists need to be the same length. Try this:
Test ? values : DSCore.List.FirstItem(values);
No doesn’t work
Why do the lists need to be the same length it is stupid…
could do a count…repeat list and then after the if set unique items…but that is a big detour
Use the scopeif+ node from clockwork, or use a simple python:
If your tracks are completely seperate you could use the OOTB scopeif node as well… though your graph will crash if the true and false tracks are not completely seperate ones.
thanks…Jonathan.
Want to stay clear of Clockwork, it crashes my Dynamo and Revit
