Good morning all, i’m looking for a way to make sure that the Family Types node I’m using is ALWAYS using the same family. Any way to use a Code Block for that? Right now i have Family Types plug into FamilyInstance.ByFamilyType
Not sure if I properly understood your query, however hope his helps. Different ways to achieve the same…
EXACTLY what i was after
I am kinda hijacking this one, but i have a similar question and i don’t quite above explanation.
In my example (see image) how can i write ViewFamilyTypes - Floor Plan 2 in (a) code (block)?
So i don’t have to pick (choose) it again (from the fly-out) when i re-open this Dynamo script?
Or, in other words, how can i ‘lock’ a choice?
Same for a Level.
Is there a place where i can find some examples how to code things instead of using node?
