List of Dictionaries
I do tried but fail to do it by myself.
I have a list of dictionaries.
I need to extract value (value=1) from the dictionary (dictionary=0), which matches the specific value (name=Order in Construction) in the dictionary (dictionary=0).
In other words, I want to get rid of code block (json[0]).
Thank you.
Hello
a solution with a Python Node
listJson = IN[0]
for jsondict in listJson:
	#convert to Python Dictionary
	dictPy = dict(zip(jsondict.Keys, jsondict.Values))
	if dictPy.get("name") == "Order in Construction":
		OUT = dictPy.get("value")
		break
Hello, @c.poupin
Thanks a lot! The code is clear. I need to start learning Python :slightly_smiling_face:
@c.poupin
There is still some error in my case…
You need to make an indent (Tab) on line 6, 7, 8 and 9 like the example from poupin (double indent on 8 and 9)
@s.semashka
read this :wink:
Thanks @wouter.hilhorst and @c.poupin That’s true… another newbie error.
Any dictionary has “Keys” and “Values” components. What’s now?
And now…
in your first screen can you add the Object.Type node? to get type of dictionary
@c.poupin please find attached below
strange, what your version of Dynamo?
you can try this
listJson = IN[0]
	try:
	except:
		dictPy = jsondict
		break
dynamooo
Perfect! That’s work. Thank you!
thank you also, thanks to you I learned that on 2.5 the Dynamo Dictionaries are automatically converted into Python Dictionaries in a Python node as input
