How do I get a list of numbers out of i.e. a number range or xyz coordinates of multiple points?
When I use the watch node i just get system.collections.arraylist
Best regards,
Rolf
Best regards,
Rolf
Hello Rolf Spandet Karstensen,
Look at attached image, is this what you are looking for?
If not, please attach picture of your graph with your expected output.
Thanks,
Ritesh
What I would like is the list with white background to appear in a watch node instead of Systems.collections.arraylist- I think dynamo 0.6.3 used to do that?
Thanks,
I am having this same issue. Has anyone found a solution?
Which version are you using? I am on 0.7.5 RC 2 and it works perfectly…
