Hi people,
maybe it is simple… but right know i can’t find out the way to solve this:
what is the best way to extend the vertical lines, getting them attached to the horizontal line?
thank you all!
JD
Hi people,
thank you all!
JD
Hi Vikram
Thank you a lot for your help!
what if, i want to control the top with two lines?
in this script, the point P5 and P6 defines the vertical lines, and the P1, P2 and 3 defines the two lines on the top, the ones I want to limit the vertical ones. How could I do that?
Thank you!
well, I gave this as solved, but i was wrong… after try to change the Top Point (p2), vertical lines seems to not follow the polycurve made from two lines. I though that this might work, but then, when I try to change the top point elevation with a slider, theres a gap between them. Does anybody have an idea of what’s going on here? Thank you! teste-linhasimples
Thank you for your help Kulkul. It seems to work fine!
