hey y’all! I Was originally trained in Grasshopper And I am having trouble with simple interphase differences between dynamo and Grasshopper. Anyways, my question is; In grasshopper you can disable selected nodes which allows for a iterative workflow, and I was wondering if there is a way to do that in Dynamo?? 12-13-14_Stairs1
Hi Daniel,
Unfortunately, to my knowledge you cannot disable select nodes, you will need to either disconnect the node or create a simple “switch” boolean.
Aww, thank you! I will play around with the “Switch Boolean” Node.
I’ve released a very simple “Boolean switch” node in package manager, couldn’t find one already. Let me know if it works for your needs.
