is there a node to export to dwg with export views as external references switched off ?
I’ve used the Genius Loci node but that doesn’t have the option to uncheck that property
The Export DWG node in Genius Loci package uses the Export DWG settings.
So you must uncheck this property in your export Setup.
That did it, thanks
