What am i doing?
Making a generative tool to find the ratio window / facade per room individually.
When I’ve completed the regular windows, I’m going to implement the curtain walls as well.
What did i achieve already?
Selected all windows and found the hosts of them.
Filtered all exterior walls (with assembly code used in our company) : to filter eventual indoor windows in a project
Made bounding boxes and then solids of all remaining windows.
Made solids of rooms in the project
(From here on the picture tells the rest of the story)
Intersected all solid windows with the solid rooms to get only rooms with windows in it.
Exploded remaining rooms to find the surface area of the wall with the window in it (via intersection of the solid windows again)
As you can see in the picture, I now have windows (as solids) with the surface containing that window for every room. Finding the area of both is no problem, I have done this in another version already.
What I need help with?
I can’t seem to find out how to link the surfaces and windows to the room ID’s (#2 in the picture). In the end I need to put the results of window/facade ratio in an excel sheet per room. Some rooms have multiple windows. I’m struggling with the list management for sure and I can’t see what I’m doing anymore.
In an attempt to come to #4 in the picture with list mapping instead of Flatten, it just gave me one result… That didn’t go as I’d hoped. (see picture 2).
I hope you guys can assist me in this one.
