Hi !
I’m trying to select my text notes in order to rotate them. However none of these 3 ways did works:
- selection by category
- selection by type
- creating text note with archilab package and seing its type
What am I doing wrong ?
Hi !
Maybe you should add a Watch
node to the outputs of the Element Types
, Categories
and Object.Type
nodes to see what’s coming out of them, this should probably work.
Hi @raphael.georges,
Text note doesn’t work with other language version than English Revit.
There is a bug with Dynamo 1.3.
It’s really weird, the first top method returns null even if the text note is created.
It does the same on my coworker project on Dynamo 1.3.2
Merci Alban, then I have to run it in English
Will that be resolved? I don’t find the bug report in github
