I would like to import the temperature data from InfluxDB into Revit via Dynamo using a Python script.
I created an InfluxDB database and I can manage it in Python.
Can someone help me?
With Influxdb, you have a few options.
Python is probably do-able, but simplest method is to use a GET request to the query endpoint, with the Dynaweb package. Something like this:
Thank you for your answer Andrew_Hannell,
It was really useful!!!
I’m trying to do import data from my influx database to revit with dynamo. I tried to do what you said but I have an error message. I don’t understand what is the probleme here, i put the same url on firefox and it worked, if someone could help me it would be nice.
I have a feeling that Dynamo picks up settings from IE (but I also thought Edge shared the same settings- so maybe this is incorrect)
Try adjusting proxy/connection settings in IE until it works there too
