Dear community,
as part of my bachelor thesis i have programmed a parametric building in python.
I, more or less, just started using Revit and Dynamo.
I want to pass the parameters of the building (e.g. building length/ width), which is the output of my “Python code”, to dynamo.
I read alot about importing it with XML/ CSV, but didn’t find a current solution on how to do it.
What type of data format do you guys recomment and most important, do I need packages?
What is the most common way to import Python code?
No, because I want to convert the pyhton code to XML or any simular data format.
The aim is to get a hierarchical structure to make it easy to “read” the code
After that I want to import the choosen data format to dynamo.
Does this make sense to you?
What data format do you recomment?
